View Poll Results: Mcleoud or Textrilla?
Mcleod Twin Disk
60
41.96%
Textrilla Exoskel
83
58.04%
Voters: 143. You may not vote on this poll
Old 01-01-2007, 02:21 PM
  #41
Robert56's Avatar
The oz700 here, with 550rwhp 636rwtq and 200 sprayed passes. Still works and drives like a charm. Currently running ET Streets and 3.42s. Tex all the way, you'll never find a better company and the service is #1. My buddy has the Mcleod twin, and that thing is a bitch in city driving, you better have some Arnold Swartz type legs. He also needs to get it rebuilt and/or replaced as spraying it has caused it to slip one to many times.
Robert
Old 01-01-2007, 02:32 PM
  #42
DoesSpeedTurnUon's Avatar
^^^ I have a McLeod Twin, and its not a problem driving in the city at all. My buddy has a Ram Twin, that thing SUCKS. STIFF and its very loud when its just sitting there idling with your foot off the clutch, sounds like its falling apart.
Old 01-07-2007, 03:40 AM
  #43
candlelit's Avatar
Tonight I installed my Tex OZ700. had it sitting next to the McLeod Street Twin and we chose the Tex over the McLeod. Upgraded the slave and the new adj. master is on it's way. I only drove it around the city block twice. Definately noticed it grabbed much harder than that Centerforce DF I had in it and definately an easy pedal to work with.
Old 01-07-2007, 02:17 PM
  #44
Robert56's Avatar
Textralia says to not use the adjustable master, doesn't need it and can cause issues. They rec the stocker.
Robert
Old 01-07-2007, 05:03 PM
  #45
candlelit's Avatar
Robert
Really? I heard the one I ordered (RAM) is just like the stock MC except it's adjustable?
Old 01-22-2007, 07:37 AM
  #46
MrDude_1's Avatar
Robert
actually, they say not to use the McLeod adjustible.... it has a larger bore... so it displaces more fluid, so the slave moves further, and that can cause issues with their special pressure plate.
the RAM is just a stocker with the end modified to be adustible... and while tolerances can build either way, and potentially allow you to adjust the pedal to the point where you overthrow the clutch.... it is unlikely.
Old 01-22-2007, 08:35 AM
  #47
^^^ Can i use a stock master with my mcleod?
Old 03-06-2007, 04:36 PM
  #48
Kaneman's Avatar
Has anyone changed there mind at all? I have a turbo 408 that should do 700-750 rwhp maybe more once I find a clutch to hold it. I have been leaning toward the Mcleod setup but lots of chosen the Exo-Skel Dual. How has the stock Master been holding up for people using the Exo-Skel Dual? I like the idea of an aluminum flywheel that Text does not have yet. Is there a big difference between the steel and aluminum?
I know this topic has been beaten to death but a few more opinions never hurts.
Thanks,
Kane
Old 03-23-2007, 12:03 PM
  #49
Kaneman's Avatar
Anyone? I have heard from a couple people it is a love hate realtionship with the Exo-Skel. I know a few people with the Mcleod that love it.
Kane
Old 03-30-2007, 12:41 PM
  #50
gnx7's Avatar
The Textralia supposedly weighs 39lbs and the McCleod is 43lbs (alum flywheel).
I'll weigh mine this weekend. I have an LS7 that should make 575rwhp and I plan to spray a 100-150hp wet shot.
2800lb RX-7 built to road race.
Old 03-30-2007, 01:29 PM
  #51
erikthegoalie's Avatar
exo skel FTW and for life...
Old 03-30-2007, 08:19 PM
  #52
Kaneman's Avatar
A friend of mine has a Mcleod and he is doing 850rwhp and says he would never go with a different clutch. I should be running about 700rwhp and about 750 torque will the Text hold it or do you stay with the proven Mcleod? Or is it the luck of the draw .
Kane
Old 03-30-2007, 08:35 PM
  #53
ls1muscle's Avatar
Another vote for Textralia, love it
Old 03-30-2007, 08:52 PM
  #54
Kaneman's Avatar
I really would like to buy a clutch that is going to last a little bit and can handle the power. The Exo-Skel sounds awesome so if no one has had regrets I may just have to give it a try.
Kane
Old 04-15-2007, 02:06 PM
  #55
hoserack's Avatar
MY Exo-skel has seated in nicely and seems to be holding quite well.
I have the RAM adj. master and it engages right at the top no problems, except some chatter once in a while.
I like the kewl sound this clutch makes while disengaged at idle.
Old 04-15-2007, 04:59 PM
  #56
marine02ss's Avatar
Can u daily drive a Exo-Skel?
Old 04-16-2007, 04:11 PM
  #57
LostCauseZ06's Avatar
i run the mcleod street twin with the stock hydralics. i have never had any problems at all and i daily drive my car to and from EVERY day, rain or shine... its been on countless road trips, it just is an awesome clutch!! ive put about 10k miles on it and i also bought it used with 5k on it... its holding awesome with no problems!!
Old 04-16-2007, 08:42 PM
  #58
BLOWNBLUEZ06's Avatar
I have one of those bad *** LUK performance gold clutches in my Z06 making 520 rwhp and it doesn't miss a lick. I don't know why you guys worry about these dual disc thingies because you don't need them!!!
OK I am just kidding. That clutch won't hold my car, so I just bought the EXO-SKEL from BYUNSPEED this morning. I'll let you know how it works after I get it installed and broken in. I just bought this car and have been hiding from people wanting to race. It makes me sick!! I had a rich ***** in a Ferrari pull up on me today and I almost threw up in my mouth because I couldn't tear a hole in his *** with my ( relatively cheap ) ride. When the clutch is in, all rich ****** in Ferrari's must die!!!
Old 04-17-2007, 07:54 AM
  #59
I just wanted to come back in here and convey ONCE AGAIN my DEEPEST LOVE for my ExoSkel....GODDAM I LOVE THIS CLUTCH!....my rear screams when I let off the clutch pedal...
E
Old 04-17-2007, 05:12 PM
  #60
alwaysinboost's Avatar
I just took out my Mcleod street twin to send back for inspection & balancing. I was real impressed with the construction. It only has around 3000 miles and 20 or less 1/4 mile passes.
4 straps FTW!!!!
you can still see the tooling marks on the friction surface.
Quick Reply: Mcleoud or Textrilla?
