ls7
Old Nov 1, 2006 | 04:52 PM
Rodrigues's Avatar
Default ls7
I am looking for a replacement clutch because mine is doing some violent chattering. I just replaced the slave cylinder 200 miles ago and wanted to know if I get the LS7 clutch, LS7 PP & LS2 flywheel will I be able to use the LS1 slave cylinder with the throwout bearing on it?
Old Nov 1, 2006 | 05:16 PM
Azar's Avatar
LS1TECH Sponsor
From what I've read, yes...you will be able to use the slave cylinder you have on.
Old Nov 1, 2006 | 07:38 PM
Hugger Z's Avatar
Yes the slave will work. I am doing the same swap. I have the clutch/PP/flywheel on my workbench and still have to get new hydraulics (and a bleeder extension).
Old Nov 2, 2006 | 08:09 AM
BIG_MIKE2005's Avatar
Yep, it will work. I didn't even replace my hydrolics. I have never had a issues with them & its a 99' model. Still working fine with stock hydrolics, new slave & LS7 set-up.
