View Poll Results: How did you spend on your rebuild?
FREE!!
![](https://ls1tech.com/forums/images/polls/bar2-l.gif)
![](https://ls1tech.com/forums/images/polls/bar2.gif)
![](https://ls1tech.com/forums/images/polls/bar2-r.gif)
![](https://ls1tech.com/forums/clear.gif)
14
8.75%
$500 - $1000
![](https://ls1tech.com/forums/images/polls/bar3-l.gif)
![](https://ls1tech.com/forums/images/polls/bar3.gif)
![](https://ls1tech.com/forums/images/polls/bar3-r.gif)
45
28.13%
$1001 - $1500
![](https://ls1tech.com/forums/images/polls/bar4-l.gif)
![](https://ls1tech.com/forums/images/polls/bar4.gif)
![](https://ls1tech.com/forums/images/polls/bar4-r.gif)
30
18.75%
$1501 - $2000
![](https://ls1tech.com/forums/images/polls/bar5-l.gif)
![](https://ls1tech.com/forums/images/polls/bar5.gif)
![](https://ls1tech.com/forums/images/polls/bar5-r.gif)
31
19.38%
$2001 - $2500
![](https://ls1tech.com/forums/images/polls/bar6-l.gif)
![](https://ls1tech.com/forums/images/polls/bar6.gif)
![](https://ls1tech.com/forums/images/polls/bar6-r.gif)
20
12.50%
$2501 - $3000
![](https://ls1tech.com/forums/images/polls/bar1-l.gif)
![](https://ls1tech.com/forums/images/polls/bar1.gif)
![](https://ls1tech.com/forums/images/polls/bar1-r.gif)
6
3.75%
$3001 - $3500
5
3.13%
Said screw it and bought a new tranny!!
9
5.63%
Voters: 160. You may not vote on this poll
How much did you spend on your rebuild?
Originally Posted by Krab
I replaced the 3/4 steel shift fork, and D&D synchro rebuild kit. Total cost was ~$325 including the tranny fluid and craftsman snap ring pliers. Labor done by me.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Originally Posted by NVR_SPDS
Bought new trans for 2500:
30 spline mainshaft conversion - same as the Viper
26 spline Viper input shaft - bigger diameter than stock - same as the Viper
Full micropolish by Performance Metal
Cryo treated by 300 Below
G-Force solid keys 1-6 gears - replaces stock stamped keys
Heavy duty steel 3-4 shift fork
1-2 modified shift fork - steel insert
New compressed carbon particle blocking rings
Bronze fork pads - replaces stock plastic pads
All new bearings and seals
All clearances set to race specs
early on when i had my orange car i blew the synchros (at the track of course). the pieces flew around the trans and took out a couple gear shafts or something... i had it rebuilt to stock at AAMCO... parts and labor cost $900.
put i did the R&R on the trans. so i dropped it off, he fixed it, then i picked it up and threw it back in the car.
T56 3-4 Steel Shift Fork 41.00 1 41.00
T56 1-2 Synchronizer Assembly 115.95 1 115.95
T56 3-4 Synchronizer Assembly 107.95 1 107.95
T56 5-6 Synchronizer Assembly 95.95 1 95.95
T56 1st Gear 39 Teeth 109.95 1 109.95
T56 2nd Gear 43 Tooth 114.95 1 114.95
T56 3rd Gear 37 Tooth 119.95 1 119.95
T56 5th Gear 58 Tooth 108.95 1 108.95
Billet Keys 3-4 / 5-6 /Reverse 60.00 3 180.00
Bronze Fork Pads
Option 1: 1-2 26.50 1 26.50
Bronze Fork Pads
Option 1: 3-4 26.50 1 26.50
Bronze Fork Pads
Option 1: 5-6 26.50 1 26.50
Bronze Fork Pads
Option 1: Reverse 26.50 1 26.50
Billet Keys 1-2 40.00 1 40.00
T56 Premium Master Overhaul Kit 435.00 1 435.00
Subtotal 1,575.65
Shipping 27.92
Total 1603.57
Did the rebuild myself.
Bronze Fork Pads
Bronze Fork Pads
Bronze Fork Pads
Bronze Fork Pads
Subtotal 1,575.65
Shipping 27.92
Total 1603.57
![Driving](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_driving3.gif)
#32
How do all of you do it yourselfers go by pressing the gears back on to the shaft? Do you just have a hydraulic press in your garage? Also what kind of puller do you use to remove 5th and 6th gear?
#33
No labor, but its taken me 9 weeks!!!!
But $742
Also Why are the damn Billet keys so expensive?!?!
and Im not running the bronze fork pads on the forks that I ordered, because they dont fit on right.
But $742
#34
But $742
But $742
#35
Originally Posted by Fire-formula 93
Where did you get your parts?
#37
I just got the bad news that my tranny was toast...I only had 1st gear out of the 6...I got the viper conversion....$2800.00 and some change on the rebuild....Looks like the last tranny I'll need....
#38
I guess im really in for it im just gonna get my T-56 rebuilt hopefully i get alot of milage on it till i save up for my TH400, Does anyone know any good shops in South Florida for rebuilds please let me know
#40
No rebuild for me. I'll be going auto when my M6 takes a dump. I've got a buddy who has rebuilt his tranny a couple of times and has always had trouble shifting. He thought it was just him but others have tried and it won't work right. I'll be going with a Jr Tranny 4L60E and a PI converter. Manual valve body with a ratchet shifter of course...to keep that "manual" shifting characteristics.
