Need help getting tranny back in
Old Nov 12, 2006 | 01:31 PM
Chilly Palmer's Avatar
Default Need help getting tranny back in
For some reason, I'm not able to get the tranny to stab all the way back in to the engine. It's lined up, and a buddy and I are pushing as hard as we can to get the transmission to mate back up to the bell housing. The splines are lining up - I can tell because the grease is being pushed back to a certain point about 1" - 1 1/4" up the input shaft. Everything else seems to be in place, but the tranny just will not go completely back on.
Any help, ideas, input, etc. would be greatly appreciated. I'm trying to get this done today and it's really frustrating getting stuck at this point.
Old Nov 12, 2006 | 01:42 PM
Blk97WS6's Avatar
same thing happened with mine. just keep trying. mine eventually went it after about an 1 1/2 hours of messing with it. make sure that your dial pins are lined up, and that they arnt bent.
Old Nov 12, 2006 | 02:22 PM
Thing is, we can't even get it close enough for the dowel pins to sink in - there's still about 1.5" of space between the tranny and bell housing, and no matter how hard we push it won't go any futher. We've been turning the input shaft by hand every so often, and I don't think it's the splines - the seem to be meshing.
Is there anything else that could keep the tranny from going in all the way??
Old Nov 12, 2006 | 04:17 PM
SladeX's Avatar
Crack the bleeder valve a bit, if the clutch was changed then I'd take another stab at it with the alignment tool.
As your tightening it down, torque a bolt a bit, remove alignment tool rotate the alignment tool 90 degrees and then reinsert and tighten another bolt. This will make sure the clutch is perfectly aligned. I got my transmission to slide back in like butter on my first attempt. Make sure all the dowel pins are clean and just take another shot at it.
Old Nov 12, 2006 | 04:26 PM
Blk97WS6's Avatar
yea sounds like the clutch my not be aligned correctly. i would take the trans back down and check the clutch again. also you can try putting the driveshaft back in and turn the input shaft to make sure the splines are meshing correctly.
Old Nov 13, 2006 | 12:50 AM
Okay, transmission is IN!
Never could get the transmission much closer, it was simply just the shim that came with the RAM Powergrip HD was large enough to raise the slave to the point that it was hitting the fingers of the PP and would not let the tranny get closer than ~ 1" or so, slight larger than the width of my finger.
After posting this, we went back out to the garage and just got the tranny as close as possible to the bellhousing and I was able to start the bottom left bolt - that pulled it in close enough for me to start working around the bottom bolts and to the pass side bolts and then back up the drivers side, MAKING VERY CAREFUL THE ENTIRE TIME THAT THE BOLT ANGLES WERE CORRECT AND LINED UP WITH THE HOLES, AND THAT THE BOLTS WERE NOT GOING TO BE STRIPPED OR BENT. This caution took a lot longer but was worth it. Eventually we pulled it in with the bolts.
Just a heads up to anyone who is installing a RAM Powergrip HD and using the supplied 0.15" (I think) shim - you may run into the same problem with the slave cylinder contacting the pressure plate fingers making it hard to get the tranny close enough. The only solution I see is to do what I did, get at least one edge close enough to start a bolt and pull it in.
My new question is - is the slave cyl. now pre-loading the fingers of the pressure plate to the point that it will cause engagement issues down the road, and/or cause the disc to wear quickly? Or is this something that will even itself out?
As a data point, the engagement is between the middle and top of the clutch pedal throw.
Old Nov 13, 2006 | 07:40 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Glad to hear you got it in. What flywheel are you running with that HD? I had a similar problem with a Centerforce a while back, and it was hitting the slave. I run an adjustable master, so I let it out all the way and tweaked engagement/dis-engagement from that point. Now I have a bucket load of hydraulic problms with it, but that is beside the point.
Most of the time the problem is that the alignment tool needs to be an actual input shaft. I had this problem with the Twin Disc when I was putting the tranny back in it as well. The plastic alignment tool will bend and scrape. I used the input shaft with the correct spline and boom! Went right in.
Old Nov 13, 2006 | 10:01 AM
I am using a resurfaced stock flywheel.
I still have the stock master cyl - I was planning to do the drill mod but we ran out of time messing with the clutch. I'll have to save that for another rainy weekend.
After thinking about it - I realize the alignment of the disc/pp was not the problem, and the shaft was going on just fine. It was that the shim was moving the slave cyl. far enough out to contact the plate fingers while the tranny was still ~1" or so out, making it impossible to get the tranny any closer without pulling it in with the bolts.
Someone please tell me I'm wrong, but I'm starting to think I need to pull it back off and remove the shim. I would hate to do that though, and then find out that the clutch will not engage at all without the shim. Anyone have any thoughts on that?
Old Nov 14, 2006 | 03:00 PM
Sonic28's Avatar
I too just installed a RAM Powergrip HD. I installed a remaned flywheel from Autozone (only $59!), a new slave cylinder/throw-out bearing from Advanced Auto, and pilot bearing. I used the shim that came with the clutch. Upon installation, I was able to get the trans in far enough to just get the dowel pins lined up. I also had the problem with not being able to push the trans in farther. I pulled it in with the bolts, like I had heard NOT to, but I couldn't get it any other way.
I now have about 530 miles on the clutch. I am waiting until 600 to really pull on it. My shifts have become smoother within the first 500 miles, and it is getting easier to get into reverse.
However, my clutch would start to engage AS SOON as the pedal was lifted off the floor. That has also gotten slightly better.
In my opinion, you need to Mityvac your clutch master cylinder.
I would not remove the shim; it is put in there for a reason.
Good Luck!
