01 slave cylinder
01 slave cylinder
i'm going to be changing my clutch here in the next month or so, and i was told i should change my slave cylinder to the 01-02 version, is this the right one? slave cylinder , and what will i have to do to change it? (new lines etc.) ?
yup thats the right one. you will have to drop the trans, but once you have the trans out there are two bolts holding the slave on. unbolt those, disconnect the quick-connect fitting, bolt the new one up, and stick the trans back in. after that you will have to bleed the system, and your done.
