Trans or clutch
Old Nov 20, 2006 | 03:21 PM
WhtFast01's Avatar
Default Trans or clutch
Well I cant tell if my clutch or my trans is trashed. Here is the problem last time i ran my car it got stuck in 4th gear on the return road but I was able to get in out of gear but then I was not able to get it back into any gear untill I let it cool down and then everything was fine. Drove the car home parked it and the next day I went to put it into gear and this time nothing, wouldnt go into gear at all. Now here is why I think it also might be the clutch, I had the clutch to the floor and tried putting it into 1st gear but it wouldnt go but when i push harder it still would not go it but the car move forward, so I cant go into gear but with the clutch to the floor and me pushing hard on the shifter the car moves......
Old Nov 20, 2006 | 08:28 PM
yellowbird1232's Avatar
Tech Fanatic
More than likely you had a syncro slider/strut break. This will jam the syncro so you can not shift.
Old Nov 21, 2006 | 07:23 AM
WhtFast01's Avatar
But why would the car move forward with me pushing the clutch to the floor and holding (pushing ) the shifter into first and it not going into gear?
