Which textralia clutch should I get??
I see these listed and I'm trying to figure which one is better, stronger for my mods power... Is it really better to go with the Aluminum Billet instead of the Steel?
Clutch - OZ700AB series - Complete with light weight Aluminum Billet with "RoseLock System" flywheel - Street Strip
Clutch - OZ700SB Series - Complete with light weight Steel Billet with "RoseLock System" flywheel - Street Strip
or should I get this one:
Textralia™ Exo-Skel™ Multi-Plate Series Clutch with Steel Billet Flywheel
[EXOSKELSB]
DESIGN FEATURES:
• Maximum surface area for greater performance.
• Machined steel chrome plated race proven carrier for extreme durability and smoother, faster gear shifts
• High performance friction material with greater cooling capacity bonded and rivetted for higher RPM loads
• 30% more clamp load over standard
• Strikingly smooth operation for a high performance clutch
• Available with Aluminum and Steel Billet flywheel assemblies
[EXOSKELSB]
DESIGN FEATURES:
