Reverse?
Old Nov 23, 2006 | 02:05 AM
Ruckus's Avatar
Default Reverse?
i just got my camaro and my clutch seems to be messed up a bit. Are you guys having trouble reversing? its a 6-speed but its very hard to get it into reverse... is it hard for the rest of you? when i bought it the owner said he had just put in a new clutch.
Old Nov 23, 2006 | 12:03 PM
calhoon's Avatar
Try it with the engine off key on. If its is easier, the clutch is dragging. Try the same with the key off. If its the same, the reverse solenoid is not connected properly. It should be MUCH harder (but still possible) to get into reverse with the key off.
Old Nov 23, 2006 | 10:30 PM
z_speedfreak's Avatar
im betting the pervious owner didnt bleed it after the new clutch install
