clutch problems
Old Nov 30, 2006 | 12:07 PM
Radcat's Avatar
Default clutch problems
My clutch works just fine when it's warm. When it has been setting out all night in the cold it doesn't want to disengage for the first 15min or so when I drive it. Sometimes it's so bad that I can't even get it in gear or when it is in gear and the clutch is to the floor the car still trys to move forward. It only does this when it is cold. After it warms up it's fine. Any idea what could be the problem?
Old Nov 30, 2006 | 01:34 PM
autotrix's Avatar
Closed ex-Sponsor Account
Sounds like you have a hydraulic problem and when the engine heat warms up the fluid, it expands, allowing the clutch to work properly. Check the fluid level. Could also be a gear case problem.
Old Nov 30, 2006 | 04:14 PM
Radcat's Avatar
The fluid was a little low but not very much.
Old Jan 14, 2007 | 05:40 PM
Radcat's Avatar
Just thought I would post an update. Turns out it was the slave cylinder.
