t56 dimensions/bellhousing height?
Does anybody have the dimensions of a t56, particularly the height of the bellhousing? A diagram would help tremendously as well.
I found a diagram that has the lengths of the transmission, etc, but it doesnt have any heights.
Here is the link to the measurements and pictures that it does have; I need to know how tall the bellhousing is, however.
http://www.5speedtransmissions.com/6_speed.html
![](http://www.5speedtransmissions.com/T56-Lengths.jpeg)
I found the dimensions of the 4L60E, would the the bellhousing be the same size, considering it has the same bolt pattern?
Here are the links to the dimensions of multiple auto transmissions:
I am in need of measurement 'E' for a t56.
![](http://www.tciauto.com/Products/TechInfo/trn_dim_small.gif)
http://www.tciauto.com/Products/Tech...bles_print.htm
According to this guy's measurements, the width of the t56 bellhousing is 430mm, or roughly 17in. Becuase a bellhousing is fairly circular, would it be safe to assume that the height of the bellhousing is relatively close to the width?
Heres the width measurement:
http://www.pistonheads.com/gassing/t...5&t=242414&h=0
