is shifting suppose to be rough
Anyway... First gear is almost impossible sometimes until Im going around 10mph or slower. It will shift in like butter as long as Im going under ten...and it will either not go at all, or feel like crap if I try it anywhere above 10. But Ive been told this is normal manual trans syncro behavior.
As for shifting into 2nd and 3rd... Some things to check. make sure you have the correct type and fresh fluid in the trans. I made the switch from Dexron III to Penzoil Syncromesh and I could feel a difference. Others have better luck with plain old Dexron...you gotta try and see if that helps. Some other simple things... Make sure nothing is preventing the clutch pedal from going all the way down. I.E. floor mats or carpeting.
Also, another big one is making sure the fluid for the clutch hydraulics isnt really black. If it is...you should flush and fill it, then bleed your clutch really well.
Some people will tell you to do the drill mod...and I would too...but I dont know for sure if that would help ya. Im sure someone else will chime in with some definites. But...check the simple things first before you start to worry about a rebuild. I see that you have some mods done to your car already...so everything Im saying might just be stuff you already know...
Justin
I shift my t56 faster and smoother than any tranny I have shifted before, over the 350z, any mustang I have ever driven and thats lots, my impreza, any impreza, any honda... oooo, my celica was smooth but I prefer the t56, dsm's shifted like butt..... I could go on.
and this will help achieve smoother, faster shifting????
