grinding rear end
My stock rear end is making a horrible grinding noise which may have started at the racetrack, but I'm not sure exactly since I usually have the radio on pretty loud. It's so loud every single person who gets in my car asks me if something is dragging or if I have a brake hung up. It's not a brake. It doesn't change with braking activity, but it does change with torque application and speed.
When driving down a freshly paved blacktop highway which makes almost no tire noise it's still hard to talk over the noise from the rear end. When I take my foot off the gas and hit that sweet spot where the engine is not pulling the car and the car is not pulling the engine (no torque on the drivetrain) the noise goes away. Of course, as the engine speed slows down the noise comes back because there is (negative) torque on the system again.
The car is not bleeding, nor can I feel anything wrong. I'm a driver who is very in tune with his car. If it were pulling even remotely or clunking/wobbling/etc... I would know it. There's nothing. Just a heckovalotta noise.
Has anybody ever had their rear end do this? Does anybody have a clue what could be wrong? I'd really like to have some ideas before I tear the car down.
Thanks in advance.
Thanks for the fast response. You think I ate a gear, eh? Ok. Any idea how ex$pen$ive it will be to fix? Do I need anything but the gear set (gaskets, seals, widgets, schnoodles?) Would this be the ideal time to upgrade to a 4.10:1 gear? Is there anything else I should consider doing while I have the rear end apart? (cheap/easy mods)
And the real question of the day "Is it even worth fixing the stock rear-end?" Of course, I have a VERY VERY VERY limited budget so the answer will depend on how much it costs to fix this problem.
Any and all help is greatly appreciated. This is my daily driver and I have an 80 mile round-trip commute. This car gets some serious MILES and I can't afford to be without it.
<img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
They don't really look that bad. There's a little bit of wear on the outside edge of the teeth, but that's it. There are no broken teeth on the ring or the pinion, and I didn't see anything noteworthy inside the posi, either.
Thoughs and suggestions welcome.
Oh, and PS. Should there be play in the axles? Like, with the wheels off the ground, I place one hand at the front of the wheel and one at the back making a horizontal line across the diameter of the wheel and push back and forth. The wheel rocked noticably and my wife could see stuff moving in the (opened) rearend. The passenger side seemed to do it a tiny bit and the driver's side did it quite noticably.
