What bellhousing for T-5 and LS1
Old 12-16-2006 | 06:14 PM
300zxls1's Avatar
Default What bellhousing for T-5 and LS1
I am in the process of doing a LS1 swap in a 89 240sx. I was planning on a T-56 but there 138lb weight is a liitle high. The T-5 weighs in at 80lbs. I really dont need 6speeds for this car and I would love to get a T-5 under the car. Does anyone know if a bellhousing is made that I can use a t-5 mated to a LS1. Thanks
Old 12-17-2006 | 02:18 AM
SuperSport4life's Avatar
Do yourself a favor and do the t-56 the gm t-5 is absoulte junk compared to the t-56. The t-5 cannot even hold a tpi 350 for long let alone the power of a ls1. Don't worry about the weight you are doing a 240 ls1 swap you don't need to worry about a few extra pounds by ensuring you won't need to pull your tranny every week if you do a t-5!
Old 02-23-2007 | 01:04 PM
535ls1mike's Avatar
is this really that bad. I am doing a lm7 with turbo swap in a bmw and the t-5 is so cheap and they are upgradeable would it be cheaper then a used t-56
Old 02-23-2007 | 04:00 PM
iGoRa's Avatar
I dont think you have T5 as a choice. forget about it.
Old 02-23-2007 | 05:22 PM
Chadder's Avatar
Yeah, they are right. The v6 guys get stuck with the t5 and even then, any more power than stock and they start breaking like crazy...and that's on a ~200hp car...
Old 02-23-2007 | 06:54 PM
Murdock's Avatar
I'm going with a tremec tko-600 for my vette project. Strong but lighter than the t-56. Lakewood bellhousing part #15005 will mate the LS1 to the old-style trans.
For more info, search in the conversion/hybrid section.
Old 01-30-2008 | 02:46 PM
bvince's Avatar
i know the t-5 is not that stong but what would you have to do to mate up an ls1. i am asking cause this would only be temporary till i can get a t-56 cause i am a full time student and dont work as much as i would like right not but i am swaping a gmc sonoma and would just like to swap it to the t-5 thats in the sonoma already just to be able to move it from point A to point B if needed tilll i get a t-56
