Is the M6 the weak point?
I know this is a lot of stuff, but I'm curious and guys on this board seem so knowledgable. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Mike
With a stout rear and good clutch I'd be more woried about the stock aluminum drive shaft <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
I just had my T56 rebuilt with stock parts. It was whining louder than my rear, but it still shifted ok <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
this is what my drives shaft did <img border="0" alt="[Fluffy]" title="" src="graemlins/fluffy.gif" />
http://harlan-engineering.com/ds/Dsc00649.jpg
If you are worried about the T-56 replace all the syncro and the 3rd/4th gear shift fork with some new parts. According to D D Peformance (one of the better tranny shops that deal with the T-56) starting with the 2002 the syncros were made of kevlar - much stronger than stock 2001 and prior. Buy an steel shift fork. Go to www.ddperformance.com
David
I have a Cartek clutch, Denny's NR shaft, and Moser 12-bolt. I don't worry about those parts. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> Now I'm worried about my stock torque arm. <img border="0" title="" alt="[Sad]" src="gr_sad.gif" />
-Andrew
1. Stock piece of **** rearend
2. Stock clutch
3. Stock aluminum driveshaft
4. T56
I haven't busted #4 yet, but I promise I will. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Tony
The t56 is much stouter than the t5's. A proshifted one should hold up to alot of abuse. (For those of you who dont know about liberty's proshift mod, what they do is mod the synchros to allow for much quicker upshifts making it easier to powershift.) The only drawback is noise and it cant be downshifted normally. You must heel and toe to downshift. Something that should be done anyway to reduce wear on the synchros. Not mention it falls into gear much easily this way.
Second, the driveshaft is a big piece of crap. Harlan's looks pretty cool all twisted like that. Mine actually twisted and exploded into 4 pieces. Take a look: http://www.sigma-epsilon.org/steve/m...haft/index.htm
I've already ate all the gear teeth off the stock posi unit in the 10 bolt (that was pretty cool to see, WTF!). About 30 teeth came out of the housing in the oil and the gears no longer will even mesh. I also replaced my clutch. And the 12 bolt is on the way. I too will be finding out if the T56 will hold up to the abuse here very shortly. I've removed all of the weak points in the driveline, so that's the only thing left for me to break.
Just ask Nineball, he know all about twisted coke cans! <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
