Torque arm Bushing
Old Jan 4, 2007 | 07:28 PM
LSGunZ28's Avatar
Default Torque arm Bushing
Again summit ships me the wrong part. >: (
what poly torque arm bushing, do you gus have, if any?
my part # was: ENS-3-1111R
http://store.summitracing.com/egnsea...=KeywordSearch
Old Jan 4, 2007 | 08:24 PM
LSGunZ28's Avatar
The bushing seems way too big for the bracket. But Im double checking with summit and it says it will fit 1993 - 2002 Camaros. WTF is up with this?
Old Jan 4, 2007 | 08:26 PM
zlover129's Avatar
you have to grind off the old mounting plates for the old rubber mount. Grind off the bubbles and punch it out
Old Jan 4, 2007 | 08:42 PM
LSGunZ28's Avatar
^ is my mechanic going to do this, if I tell them your advice?
Old Jan 4, 2007 | 10:01 PM
SSTYCOON's Avatar
he can if hes not stupid. all you need is a angle grinder or such. Its not hard at all...trust me.. oh don't let him charge you xtra for doing it either!
Old Jan 4, 2007 | 10:18 PM
LSGunZ28's Avatar
how much should this run for?
I feel like I was ripped off....
I was charged 206 bucks today for
parts:
-Oil filter
-5.5 qt mobil 1 synthetic
- coolant/antifreeze
labor:
oil change
coolant Drain and refill
power window motor replacement ( I bought the part somehwere else , excluded from charge )
Old Jan 4, 2007 | 10:42 PM
SSTYCOON's Avatar
well if you would have done it yourself... you probably would have saved around a 100$
40$ for oil&fiter
40$ for window motor....not hard to replace.
15-20$ for coolant
Old Jan 4, 2007 | 11:32 PM
LSGunZ28's Avatar
40$ for oil&fiter
15-20$ for coolant
I know. I didnt have the time or tools to. Well actually I did have the tools for these services specifically, but I dont for other services that I will soon.
Anyways I had the window motor already.
Old Jan 6, 2007 | 07:02 PM
MeentSS02's Avatar
Kleeborp the Moderator™
Did you get the torque arm bushing figured out? You have to drill out 4 total rivets that hold the rubber pieces in the stock clamshell...2 on each side. The rubber is bonded to some small pieces of metal, and the rivets hold the metal in place. With those out of the way, the mount will fit with no issues. As for the labor...it was probably about right for the time involved to do all of that. Window motors, if you haven't done them before or in a while, take a little while to replace.
Old Jan 6, 2007 | 09:13 PM
LSGunZ28's Avatar
I am taking it in tuesday... I will copy and paste what you wrote down
Old Jan 6, 2007 | 09:43 PM
Revelation Z28's Avatar
easy way is to totally remove the torque arm and slide it out of the bushing, then unbolt the clampshell from the trans and then take the rivets out.
