how many times can you resurface a flywheel?
I had a clutch changed last year and I had the clutch resurfaced, but its time for a new clutch again
do I need to get another flywheel, or should I still be able to resurface the old one a second time?
I dont know how much he had to rub off, but i dont think it was anything out of the normal.
thanks!
thanks!
The Bull
Re: how many times can you resurface a flywheel?
Technically the flywheel is a zero tolerance flywheel. You shouldn't really have had it resurfaced, unless you had it blanchard ground. Obviously the adjustable master makes up for some of the losses there versus the stock setup though. I would say to get a new flywheel with your clutch. That might save you some pain and frustration. Not sure what would happen if you resurface the flywheel a second time.
getting a new flywheel with teh z06 clutch i ordered. great tiem for me to do the drill mod also, hope to attempt it this weekend.
thanks for the input!
