Anyone toasted a LS7 clutch?
Mine may be fried after 10K miles, I find out Thursday.
All street driven, stock engine. ZERO track time.
Stock lasted 40K.
Spec 3i lasted 15K.
LS7 (probably) 10K.
I spend a LOT of time (45min+ each way) in stop & go traffic due to the work commute.
This is getting ridiculous.
Stock lasted 40K.
Spec 3i lasted 15K.
LS7 (probably) 10K.
Still man, those are very short clutch lifetimes. My clutch has 80k miles on it (original still going), and I spend about 30+ mins in stop & go traffic monday thru friday. My car is making 400rwhp also, not to mention I was spraying it for a while . I don't know if my clutch is just a factory freak, or if most of the people here are just slipping them too much in daily driving (I'm referring to the non-racecar crowd). Let us know how yours turns out, I dont think I've seen an LS7 clutch die so fast. Could it have possibly been installed wrong (mis-aligned, etc)? Good luck getting it fixed, man.
Yeah, 10k miles is a very short lifetime for a stock style clutch. GM expects it to live behind 500 flywheel horsepower for at least 36k miles. Did you use a new flywheel when you installed it? Did you balance the entire assembly before installing? If it is a reused flywheel then the surface machining may not have been done well. Something definitely does not seem to be right with the install or the clutch itself.
Internet Mechanic
Stock lasted 40K.
Spec 3i lasted 15K.
LS7 (probably) 10K.
Stock lasted 40K.
Spec 3i lasted 15K.
LS7 (probably) 10K.
Slipping any clutch too much can burn it up easy.
Mine has been holding up now for about 6k & I drive the **** outta it. Its daily driven & my drive to work is about 30-40 minutes each way. Not to mention I'm always gettin on it & playin around. Also made about 6 passes at the track with it.
Pedal still feels perfect & actually has really smooth engaugement at high RPMs on the street & track.
New flywheel, package pre-balanced from t56rebuilds.
Professionally installed.
The stock clutch I may have prematurely replaced, pedal was sticking to the floor more than it was slipping. The Spec was just a POS. I hope something else is awry with this one.
Even with alot of stop and go driving I would expect the the LS7 clutch to last much longer. Especially with a stock engine, daily driven vehicle. Something is amiss somewhere.
Originally Posted by Phil'sC5vette
mine lasted 1500-2000 miles before the pedal started to stick and I replaced it with a textralia. I hav eabout 420 RWHP
Originally Posted by wkniffin98ss
When I got mine it did the same thing from day one. I bought the clutch and the ls2 fly wheel at t56 rebuilds. I thought it was my master and I changed that and now I am having the same problem all over again. My guess is its a factory deffected pressure plate, I have heard of a few other people with the same problem and that is what it turned out to be.
I'll know today or tomorrow.
if it is shot, why not give textrillia a shot? the reason i say this is because it seems to be the general consensus that textrillia seems to be the only clutch up for the task of street driving from what i have read on these boards... i have a spec 3 in my car and its lasted 6k so far. im putting a heads/cam in my car and i willl be surprised if it lasts through this season. i will be doing a textrillia and a t56rebuilds tranny when it does
Second_Infinity,
What year is your car? Did you replace the hydraulics? Let us know what you find out.
I know most members agree that the textralia is badass, and I don't doubt that, but a stock car should not be burning up clutches like this!
Shirley Temple Drinker
Sounds like someone needs to learn how to drive, honestly. My stock clutch has 140k miles on it, and only slips on power shifts, and our 99 was still on the original when we sold it with 60k on it.
110,000 on the stock clutch just starting to slip with 315/17" DR's i thought i had a freak but i guess not there are guys out there with more miles on their clutches than mine. for a GM clutch to fail in 10K miles or less somthing has to be wrong the clutch must not be fully engaging fully.
The car is a 2001.
The clutch was removed this morning, and appears to be just fine. No burn/slip marks anywhere. What should we look for to see if the pressure plate is defective? Nothing is visibly distinct...
So far:
- Car shop says the clutch is fine, transmission is probably the problem.
- Transmission shop says (from described symptoms) that he doesn't think it's a problem with the tranny but with the clutch instead. The transmission is now sitting at the transmission shop - to be looked at next week.
And to LSGunZ28, I don't ride the clutch at all. I don't slip the clutch if I can help it. I've never powershifted.
So far:
I dont know exactly, but the guy I talked to said he noticed it when he put the clutch in so but had never seen the clutch before so thought it was desighned that way and later on came to find out that it was a factory deffect. So it should be visible. But I will talk to the guy asap and find out for sure.
