play in t56 input shaft- is it normal??
I was able to move it up and down about 1/8" or so, and left to right almost as much, I dont think this is normal...... Is it?
I plan on installing a new pilot bearing.
also there are no dealers in my area that have pressure plate bolts and flywheel bolts, am i a complete idiot if i reuse them?
thanks in advanve
just finished with the install, took 10 hours, had a problem getting the pilot bearing out, and had to leave it in there with a little bit of toilet paper, nothign worked, the toilet paper, grease, some remover tool i bought that was too big..... i gave up on it, and kept that pilot bearing in there, hopefully i didnt damage it....
