Clutch setup help
Old Aug 24, 2002 | 06:35 PM
theblur98ss's Avatar
Default Clutch setup help
Just got done installing a spec stage 4 clutch. The pedal doesn't have much pressure but still shifts and drives. The clutch isn't as grabby as I was expecting. It can still be slipped pretty easy and isn't real jerky. I replaced the slave as well. I'm guessing that I still need to do some more bleeding. I gravity bled the slave and I'm waiting for my mcloed adj master that should be here this week. Anything else I should look at?
