T-56 Transmission Problems
Also, *sometimes* not all the time, its hard to shift into any gear, especially first, but once again if i pull the shifter up while shifting it helps, or sometimes if i push it down it helps.
Other time, the car shifts perfect 1-6, but reverse still has problems.
Any suggestions would be great, it has a brand new clutch, master cylinder and slave cylinder and flywheel.
Thanks
Sounds like you have hydraulic issues there.
Is it bleed?
Not one that needs a shim? I like adjustable master just so you can adjust the freeplay out of the pedal.
Lots of times in a manual car it helps to put it in a foward gear then go reverse w/ clutch depressed & it helps it go in R smooth as well.
