Car won't Go into Gear
Old 02-07-2007 | 06:12 AM
Freddyrdzls1's Avatar
Exclamation Car won't Go into Gear
hey i currently bought a 99' z28 and i hadn't had a problem with it until out of a sudden the car at the stop light did not want to shift into any gear. just like the other post on top, when its off, i can shift it into gear but as soon as i turn it on, it starts to move forward. i stopped the car as soon as i got that problem and friends have told me i need a new clutch and master cylinder and slave.. clutch is a centerforce dual friction with less than 12,000 miles . what should i do????before spending any cash, what and how can i check my car??? any steps on bleeding the lines??? i would really appreciate ur help thanx people...let me know what u think
Old 02-07-2007 | 06:54 AM
90LS1TOY's Avatar
If I was you I would start by checking the hydraulic system first.it sounds more like the clutch is not disengauging .
Old 02-07-2007 | 10:45 AM
TA4EVR's Avatar
had the EXACT same problem. mechanic tore mine apart and said everythign looked good, said you could tell the clutch was still new and everything. but he said the flywheel had been turned and not shimmed so he thought i needed a new flywheel...i'll get it back tonight and we will see.
Old 02-07-2007 | 05:48 PM
OUTLAWZ RACING's Avatar
Check ur pressure plate bolts dose ur car vibrate? I had the same problem.
Old 02-08-2007 | 02:18 AM
doesnt vibrate too much just a bit being that it wont engage into any gear while its on
