Update on T-56 issue
Old Feb 7, 2007 | 04:08 PM
LSGunZ28's Avatar
Default Update on T-56 issue
My car is able to shift in all gears.. the problem is...
I seriously have to put massive torque on teh shifter to engage it in gear..
Like horizontal Bench pressing my shifter or something..
It gets stuck in any gear I put it into
Reverse, 1,2,3,4,5, ......I havent tried 6th yet....
Also when Im in 1st gear teh car kind of shakes like its going to run....
Another thing is.. when in 2nd gear and Im cruising or accelerating at a higher RPM like 2500 or above, the shifter is vibrating severly..
Now Im reconsidering what I need for my T-56 parts I was gonna originally buy..
Old Feb 7, 2007 | 04:44 PM
OUTLAWZ RACING's Avatar
Check ur pressure plate bolts. But sounds like syncros
Old Feb 7, 2007 | 05:38 PM
LSGunZ28's Avatar
Synchros for sure, but It has to be more than that... Something is broken. and I hope my gears are in good shape..
When I used to grind it was synchros for sure. but what could cause extremel hard shifting. Its not grinding into gear, Just extremely difficult to shift..
Old Feb 7, 2007 | 08:02 PM
Phynix's Avatar
mine did that as well before I rebuilt it, it was just the synchros
Old Feb 7, 2007 | 08:53 PM
gun5l1ng3r's Avatar
I live very close to you, where did you have yours rebuilt?
Or did you do it yourslef with some gear pullers and some snap ring pliers?
Old Feb 8, 2007 | 01:52 AM
LSGunZ28's Avatar
Well I would hope its that simple..
Old Feb 11, 2007 | 01:24 PM
LSGunZ28's Avatar
^^^^^^66
Old Feb 11, 2007 | 10:33 PM
calhoon's Avatar
First off torque is twist and if thats what you are doing to the shifter, you are doing it wrong. High shift load( that is fore/aft) and hrd to pull out of gear are aclassic sign of a poorly releasing clutch. Let this go on and you will also generate trans probs.
Old Feb 11, 2007 | 11:37 PM
LSGunZ28's Avatar
Im not twisting it. It was used to express the strength I must apply to move the shiter into gear... I dont poorly release the clutch at all... I powershift too much and now its taken its toll on me.
Old Feb 12, 2007 | 08:23 AM
calhoon's Avatar
What I mean is your system may not be releasing no matter how well you time your shifts.
