Grinding in upper RPM's
Old 02-08-2007 | 03:35 PM
sdbrown84's Avatar
Default Grinding in upper RPM's
Well not too long after my LS7 flywheel and clutch swap I have been experiencing a very loud griding (sounds like you missed a shift from idle to 1st) when I shift above 2500 RPM's.
Also, while driving above 25 MPH and I put the clutch in to give a few revs it sounds like a bad rattle in the bell housing.
I do have 100K on the tranny now, and the car has about 450-500 HP. I am thinking about just having it rebuilt.
What do you guys think it is?
Old 02-08-2007 | 07:55 PM
98_1LE's Avatar
Start by changing the fluid, and use GM Dextron III, not synthetic anything. If that does not fix it, the synchros are toast.
Old 02-08-2007 | 11:59 PM
sdbrown84's Avatar
Yeah it sounds pretty bad. I think it could be the synchros. I am thinking I may just take this time to get a properly built tranny from T56 rebuilds...
Any other suggestions?
