clutch fluid
Old Sep 2, 2002 | 02:17 AM
Ike's Avatar
Ike
Default clutch fluid
Does the clutch fluid need to be replaced before doing a clutch upgrade? My car currently has 14,800 miles on it, but I have no idea what the scheduled maintainance is on the clutch fluid. I plan on replacing my clutch next year.
Old Sep 3, 2002 | 08:45 AM
buschman's Avatar
Default Re: clutch fluid
Check your resevior(located to the right of the brake master cylinder). If the fluid is black it needs to be replaced, if not you should be fine with only 14K on the clock. I just swapped out my clutch at 23K and did the clutch fuild then as well and the fluid looked fine. But it's a good idea to change it out every now and then. When you do your clutch, that would be a good time.
Good luck,
Mike
<small>[ September 03, 2002, 08:52 AM: Message edited by: buschman ]</small>
