Corvette Knob
You may want to check to make sure it'll fit. When I worked at a body shop, I tried getting a C5 shift *** for my T/A. Turned out the ***'s diamater was smaller than the stick in my car and wouldn't work. Just a thought
That is true, the **** diameter is different. I had found a place once that actually fixed Corvett ***** to fit F-bods but I can't remember the site I went to. I will see if I have it saved and if I find it I will get it to you. You might be able to google it and find it.
Found it, here's the link http://www.gscreationsllc.com/review...53026ff4743afa Scroll down to the 3rd item.
