? bout clutch break in
i just installed a spec 3 , . i know its a 500 mile break in but i was wonder do u slip the clutch like u do on a stock clutch or drop the clutch. . also i have to take a trip in a few days. .is it going to be already with out the 500 break in mile ima try and put at least 200-300 miles.. is that ganna be ok
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Do not...I repeat do not slip the clutch until it's fully broke in and even after it's broken it, minimal slip or say goodbye to the clutch fast. And I would raise the 500 mile to 1k to break it in. Give it a few half throttle pulls around the 500 mark but that's it. Don't go WOT until after you hit 1k. It will chatter a lot until you get to the 500-600 mile mark. Don't worry it will go away.
I did this the exact way when I broke mine in 4 months ago. The chatter is gone, and the clutch grabs like a ****. I still do not slip it though. That's a killer when it comes to these Spec clutches.
