Bellhousing Help!!!
Old Feb 25, 2007 | 07:08 PM
RICEBURNER's Avatar
Default Bellhousing Help!!!
so im replaceing my clutch for the first time in my baby and i cant figure out how the hell to get to the top two bolts! i have removed 6 and the two starter bolts. just the two up top! any help?!? tips? tricks? thanks guys!
Old Feb 25, 2007 | 07:12 PM
WS6.Jay's Avatar
Unbolt the tranny from the bellhousing, then the bellhousing from the block. To get to the top ones, the easiest way is to get a couple feet of extensions and attack it from the tail of the tranny, helps to have 2 people.
Old Feb 25, 2007 | 09:37 PM
Blk97WS6's Avatar
i pulled mine out all at once. It took a little wiggling to get it out, but it wasnt to bad. but to get the bolts out, like mentioned above your going to need lots of extensions. And yes it helps to have 2 people, one person to turn the wrench, and one person to hold the socket on the bolt.
Old Feb 25, 2007 | 10:04 PM
RICEBURNER's Avatar
JAY, is there any seals that you have to replace when removing the trans from the housing? and with the extensions, how can you get enough tq. on it?
Old Feb 25, 2007 | 10:12 PM
Xtnct00WS6's Avatar
you should be able to get it just fine with the tranny out. Also, be prepared to pry on the bellhousing a bit to get it out. Mine was pretty stuck on there.
Old Feb 25, 2007 | 10:16 PM
chuckyt1's Avatar
I've got one long extension, (24 inches I think) that and a u joint works every time. You just have to reach up and make sure the socket is on good. And I only use six point sockets on 'em...
Old Feb 25, 2007 | 10:24 PM
keliente's Avatar
No seals/gaskets.
Get a few looooooong extensions to do the job - swivel 6 point socket also makes life easier. It is a bitch but it can be done.
Old Feb 25, 2007 | 10:25 PM
Blk97WS6's Avatar
nope no seals to replace. and as Xtnct00ws6 said be prepared to pry a little.
