Clutch engagement issues
I tried reading thru the threads and search with no luck. The clutch fluid was a very minimal amount low (you typically wouldn't add anything if you seen it.), but it was dark and dirty looking. Is it possible that a simple clutch bleed would fix it? Should I go to the bleedar screw for ths one? Any help or links would be great. how long has it been installed?
You should try bleeding it since that's an easy check.
If it doesn't work try this if you can safely: Start the car in gear then when you're accelerating depress the clutch. If it slips then you probably have a broken pressue plate, if it doesn't then you probably have a failed slave although it probably wouldn't feel normal.
Either way, if bleeding doesn't solve it, you will probably need to pull the clutch.
I have had this issue with mine and a few others now
When they loosen the clutch spring(fingers) move away from the slave so the slave won't reach. Its not loose enough to make the disk loose inside but the hydraulics just won't reach the fingers
Hopefully I can pull the trans and do the slave next weekend.
