Torque specs?
Old Feb 28, 2007 | 11:09 AM
Bandit28's Avatar
Default Torque specs?
Does anyone have the sequence or torque specs for the M6. thanks for the help.
Old Feb 28, 2007 | 11:31 AM
Bryan @ Speed Inc.'s Avatar
what bolts!? lol
Old Feb 28, 2007 | 11:32 AM
flywheel to crank?
clutch/pressure plate to flywheel?
trans to bellhousing?
bellhousing to block?
trans mount?
shifter bolts?
trans case bolts? (rebuilding???)
Old Feb 28, 2007 | 12:25 PM
Bandit28's Avatar
my bad flywheel bolts and pressure plate bolts
Old Feb 28, 2007 | 12:34 PM
flash12t's Avatar
http://www.ls2.com/boggs/torques/clutch.htm
Old Feb 28, 2007 | 12:44 PM
Bandit28's Avatar
That doesnt give me the sequence... I need that please.
Old Feb 28, 2007 | 01:17 PM
brad8266's Avatar
flywheel bolts get 72lbs, PP bolts get 52, as for sequence you should be fine just doing a cross pattern and torque the bolts in 3 steps instead of just one.
