t56 rebuild
is there an up or down side on the synchro assemblies or does it not matter?
also, the teeth on the gears are worn, none missing any teeth or anything, but there is wear. how do i know if they are still good? i might be able to take some photos up.
thanks!
right now i could probly tear one down in 45 minutes. its really simple Scgt1
As for your second gear what year is your car? as some of the eariler t56s had poorly designed syncro teeth (circled teeth in the picture), and it is pretty common for the syncro teeth to completly sheared off. If your car seem like it is in neutral that is most likely because the teeth are sheared off.
Of course while I'm in it anything else that is worn will be replaced also.
I helped Vern our NTTGA club president install his T56 in his bird. I don't want to do this more then once. Its a hell of a pita. Also I don't have the puller to remove the 5th and 6th setup in the tail to remove the rest. What can be used in place of it? Or do I need to contact the guys in houston about making me one?
Edit Oh hell that looks like it would be you. LOL I just looked at your sig.
