Textralia Clutch Problem
These Textralia clutches are starting to show signs of problems. People were swearing by them in the beginning. Some still are! I'm having some of the same problems. Jared said it was because of the m/c, and is sending me a new clutch. One thing I can say w/ certainty is they have excellent customer service. Not so sure about the product yet. Some of the local guys here have also had problems.
Unfortunately I've had nothing but problems from day one. Clutch problems apparently are so hard to diagnose. I've replaced the master cylinder, twice replaced the slave, and now I'm getting ready to pull out the clutch for a final time and replace with an LS7. Pete has been very understanding and has never hesitated to send replacements. The $500 labor to R&R each time is starting to hurt, though. If it comes out again I think I'm going to have to give up on Textralia.
I vacuum bled the clutch again today and I still have start of engagement immediately off the floor. It takes almost the entire pedal travel to full engage. To me it feels like something is not right with the clutch. Next week I will have my mechanic flush and do a standard two-man bleed. That will likely be my last attempt.
Thanks for all the help guys
I had that with my "Z" grip. After switching to the "X" grip I had no more noise. The "X" grip is more of a street design with less ultimate holding power but still far and away more than I need for 411rwhp. Pete took care of me on that.
I vacuum bled for another 15 minutes on Sunday until no more bubbles. Now the car starts to roll with the pedal 1/2" off the floor. Better, but not what I would call acceptable. Am I wrong? Should the car start moving at such a low pedal height?
Here's what I did (albeit not cheap):
1. Added a bleeder extension line to the slave cylinder so that the bleeder screw is back up by the master cylinder reservoir (steve-d on here makes them).
2. Wrapped BOTH lines in heat wrap on the WHOLE line. I put shrink wrap tubing around that to make sure nothing would move or come unwrapped.
3. Used a good DOT 4 brake fluid for the hydraulics (Ate Super Blue)
4. Bought a pressure bleeder from Motive along with the right adapter for the clutch master reservoir. Pressurize it, open the bleeder screw, and watch the bubbles come out.
I haven't had a bit of trouble since.
Thanks again,
John
