Spec questions
Old Mar 7, 2007 | 06:23 PM
JakeY2KZ's Avatar
Some friends and myself had to drop the tranny 3 times before we found out that the shim was out of place. Everytime we went to pump the clutch, fluid would start leaking. We actually destroyed a brand new slave b/c we didn't line it up correctly.
Old Mar 7, 2007 | 11:00 PM
speeddemongto's Avatar
guys the hydraulics in my GTO are different than your fbodies right? because I know of an 04 GTO guy who put in a spec stage 3+ and had massive problems with the clutch,yanked out the shim and it works perfect now
Old Mar 8, 2007 | 07:08 AM
brad8266's Avatar
That really throws a wrench in the "shim needed" idea.
Old Mar 8, 2007 | 11:09 AM
JakeY2KZ's Avatar
The spec3's need the shim no matter what. The spec3+ doesn't need the shim since it's a different sized disk.
Brad..I forgot to look at your sig. I just now noticed you have a 3+. You will not need the shim. I thought you said you had a spec3...that's my fault for not paying attention.
Old Mar 8, 2007 | 11:16 AM
SPEC-01's Avatar
Jake: Though I appreciate your assistance with the information provided the point you make about the shim in reference to stage 3+ is incorrect. The shim is required on all clutches for Ls1 F-body models.
Speed: As for the GTO question, we actually have customers using the kits with and without the shim. though one would imagine that there should be no variance from one car to the next this simply isn't the case. That being said, it really depends on the car. I would suggest using the shim but you may find that the pedal is high after installation. If this is the case then pull it back out. Let me know if you have any further questions. Thanks,
Old Mar 8, 2007 | 11:19 AM
brad8266's Avatar
OK, thanks.
Old Mar 8, 2007 | 11:20 AM
brad8266's Avatar
So should the shim be used with the 3+ or not in your experience?
Old Mar 8, 2007 | 11:31 AM
SPEC-01's Avatar
Yes it should be, I am sorry if that was not clear in my last post. Thanks,
Old Mar 8, 2007 | 11:37 AM
brad8266's Avatar
Actually it was clear in your post, i just somehow skipped that line, lol.
Old Mar 8, 2007 | 11:40 AM
JakeY2KZ's Avatar
I've known a couple of friends running the 3+ w/o the shim. Engagement was perfect and had no problems. To each their own I guess. I agree that it will be different with each car. I just hate to see someone use the shim on the 3+ and then turn around and have to pull it b/c it wasn't needed.
Old Mar 8, 2007 | 11:44 AM
brad8266's Avatar
I dont mind if i have to pull it anyway. Dropping the trans is pretty simple so i will put the shim in today and if I have problems i will take it back out.
Old Mar 8, 2007 | 01:57 PM
  #32
SPEC-01's Avatar
Jake, Thanks again for the "experience" references. I always base the information I provide on the experiences that I have had as well. Remember, the stage 3+ does use a thicker disc but this is not the only difference...the pressure-plate is cut accordingly. That being said geometry is maintained. This is why the shim is used in all F-body applications.
Old Mar 8, 2007 | 11:42 PM
  #33
1bdbrd's Avatar
Jeremy, nice name BTW (thats mine name as well), which would you recommend? Im shooting for right around 500rwhp on the bottle but what something thats not a pain in the *** to drive on the street. Also what do you know about slipping the clutch out during stop and go driving? Are people having problems with that because of break in problems or...? Also, do you sell clutches direct?
Old Mar 9, 2007 | 11:08 AM
  #34
SPEC-01's Avatar
I am really a big fan of our 3+. It is the premium set-up, providing great torque capacity and easy drivability. It is certainly possible to slip it a bit during daily driving without issue. It handles heat well and has a really good wear characteristic. I have run 3+'s in my car and have always liked them (of course I am a bit biased). As long as you break-in the clutch properly and use a flat flywheel you should be set. We do sell clutches directly or you can buy through any of our dealers (a few are sponsors of this forum). Let me know if you have any further questions. Thanks,
Old Mar 9, 2007 | 12:56 PM
  #35
Disturbed Bird's Avatar
i have a 3 in right now. and i have a 3+ waiting to go in.
Old Mar 9, 2007 | 01:05 PM
  #36
Bryan @ Speed Inc.'s Avatar
i had 2 cars w/ spec 3's in them... never even got the shim in the box... needless to say i didn't install it.
never had a problem....
Old Mar 11, 2007 | 12:17 AM
  #37
thanks! I am debating on it......I will decide on it when I install it
Old Mar 12, 2007 | 11:44 AM
  #38
SLP4CamaroSS's Avatar
do yoou need to use the shim
Old Mar 13, 2007 | 06:20 AM
  #39
basically its a crapshoot
Old Mar 13, 2007 | 06:25 AM
  #40
brad8266's Avatar
I just installed a 3+ with the shim and a McLeod master and a new slave. So far it seems to be a great clutch, it does take a slight more bit of gas though.
