RAM billet flywheel part number?
I have a 402/910 combo about to go in a Trans Am, should I just surface the stock flywheel and go with it, or should I get the billet flywheel from RAM?
If I absolutely positively need the billet flywheel - where to purchase it and what is the part number?
I got the disk/PP from Summit...
Re: RAM billet flywheel part number?
I would not run the 910 on a stock flywheel. Will probably wear very quickly. Use the 980 if you MUST use the stock one. There are other mods to make this work on the stock one, do a search for details. I cannot recommend doing it. The RAM flywheel is pn 1550.
<img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
