VERY frustrated AGAIN
Now a few minutes ago, I got in the car, drove to AutoZone (which is 1 mile from my house), and got back in and it wouldnt go into any gear. I was able to nurse it home by putting it in first and starting the car. Tried to bleed the system, bled 10-12 times, still wont go into gear.
Anyone have any suggestions? I'll probably pull the trans tomorrow if bleeding it again does nothing.
You put a medium sized tip on the tube, and stick it down in the clutch fluid resovoir, and bleed it from there, not the bleeder valve.
I pulled the tranny a few minutes ago, LS7 clutch shows no wear and flywheel looks almost perfect...no hot spots, even though I have launched it MANY times since the install. All bolts were extremely tight, (I wish I didn't use red loctite).
I'm going to go ahead and install a new slave cylinder and master cylinder to see if thats the issue. This time I'll get them from a friend who works in GM parts.
