1-2 shift grind question...
Old Mar 28, 2007 | 07:36 PM
lt1_fool's Avatar
Default 1-2 shift grind question...
If the 1-2 shift on a T56 has been grinding the 1-2 shift intermittently for the last two years, would that mean a synchro is out, or possibly the gear is worn, or both? Wanting to buy this car, but don't want to open up a can of worms.
Old Mar 29, 2007 | 10:48 PM
wrencher's Avatar
wrencher
It could also be a clutch release issue.
You would not know what was wrong w/ the trans internally till it was disassembled & inspected.
It one of theose fix it while your in there & do it right the first time kind of things.
Re-build it & upgrade it & not worry about it anymore IMO.
Old Mar 30, 2007 | 08:00 AM
calhoon's Avatar
Well it may have started as a clutch release issue but if you've been clash shifting( even intermittently) for 2 years, you now have worn synchros from it.
Old Mar 31, 2007 | 03:22 PM
SpdFrk1990's Avatar
I agree I had a car that done this also.
Old Mar 31, 2007 | 09:34 PM
fastss's Avatar
Hey guys dont mean to hijack the thread but it has to do with the same issue but with me it happens when i down shift from 4th to 3rd ill grind once in a great while!!!! would this be the same issue or something different?
