Leftover part?
Old Apr 1, 2007 | 03:25 PM
A-Dub's Avatar
Default Leftover part?
I pulled my clutch master to do the drill mod. When I removed the clutch rod from the pedal, a white plastic sleeve came with it. I assumed the sleeve was a bushing between the clutch rod and the pedal stub. Well when I went to put it back in, I discovered the white sleeve will not fit over the stub on the clutch pedal. Where does this sleeve go?
