clutch work...some basic questions
Old 04-01-2007, 08:50 PM
teke184's Avatar
Default clutch work...some basic questions
if i have my flywheel resurfaced...do i have to install a shim behind it? or can the difference be taken up with an adjustable mastercylinder?
how much is a GM replacement throwout bearing? i see a centerforce unit online for $80...sounds like ALOT.
is a SPEC 3 clutch disc compatible with the SPEC 4 pressure plate. my 4 disc is worn out, and i can only find the 3 online (not to mention i think i'll get more life out of it).
thanks
