curious about t-56
Old Sep 27, 2002 | 06:05 PM
p99ta's Avatar
Default curious about t-56
I have a t-56 with a mcloud kevlar in it. I have the 02 slave and the adj master. I noticed that it seems that when it gets hard to shift, I can make it better by adjusting the master up higher... but then it gets back to the same situation in a week. I also noticed that the driver side header is close to where that is. Is there a possibility that the header is causing something to go wrong by adding heat? My throw out bearing is making lots of noise at idle too I think. I just don't understand why it would go back to the same only a few days after each time after I adjust it. Do I need to bleed the system instead of adjusting the master?
or are my syncroes really just going?
I'm lost! lol
Thanks
Chris
Old Sep 27, 2002 | 09:36 PM
wrencher's Avatar
wrencher
Default Re: curious about t-56
Flush your fluid out with a high grade fluid it helps.
