HELP! need T-56 identification!
![Exclamation](https://ls1tech.com/forums/images/icons/icon4.gif)
I just bought a complete Borg Warner T-56 6 speed manual transmission from a 1995 Pontiac Trans Am with 84000 miles. The trans is going into a 1991 s10 ith an Lt1. Its a nice looking trans but heres the problem...
I was playing around with the shifter(not in the truck yet) and I couldnt find reverse or a 7th slot for a gear??
I googled some T-56 shifter images just to see where it was and i couldnt get it over far enough to get it into reverse if thats where it is.
The # of the trans is 13-86-065-902 is this a T-56 number or a T-5 number?
I checked Tremec's site and found all the T-56 transmissions they offer start with 13-86 and end in certain numbers. Mine ends in 902 and i didnt see any?
Are the middle 3 digits, and the first 2 of the last 3 numbers tranmission specific?
All help is appreciated, thanks in advance.
Here is the T56 tag that was on my 97.
![](http://thumb13.webshots.net/t/53/553/2/64/26/2542264260044372733pqRDoG_th.jpg)
I know the number on the top right (E0673) reads like this and is the date of final assembly.
Here is how mine translates:
E=the month; so May.
06=the Date; so the 6th.
7=the year; so 1997
3=Third work shift or graveyard shift.
Maybe that can help. At least you can confirm if it was assemblied in 1995.
Also, their is no way you can mix up a t56 from a t5. They look alot different.
Good luck
JD
7=the year; so 1997
Good luck
JD
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
That # you gave is the case casting # not the model #. You should have no problem with that trans behind an LT1 as long as you use the F-car LT1 release system parts and bell.
The part number is on the metal tag. Something like 1386-000-006, 009
The reason you can't find the reverse gate is because you need to power the reverse solenoid ( the black plug one nearest the shifter) . Power releases the inhibiting load and allows entrance to that gate..
1386065902, 1386065902m, borg, casting, code, id, identification, number, numbers, speed, t56, trans, transmission, tremec, tremek, warner
