How Do You Fix a Sticking Clutch?
My clutch sticks. I know because when parked on an incline in gear if I push in the clutch the car doesnt roll back right away. It will slowly roll back and then the clutch finally disengages and its like normal. Plus, I put the rear on jack stands and the tires would turn a little bit even with the clutch in.
Im thinking an adjustable m/c might not fix the problem. I wonder if the flywheel needs to be resurfaced or replaced. Not sure what the cause is and dont want to start wasting money replacing things that are ok.
Its a 2000 with 68000 miles. Its weird because the clutch doesnt always stick. Bleeding sounds like a good idea. Although its a pita its doesnt really cost anything.
So whats the deal with the slave? Are some of them defective? If so whats wrong with them?
