Which RAM and flywheel (is there difference between makes)? Drivability?
Needs to hold 500-550rwhp/tq in a turbo car daily driver. The RAM Level 3 looks good (rated for 500hp) or do I need Level 4. Is this the HD version? What is the HDX version? They good for a daily driver?
Also, what flywheel should I get? I figured the stocker should be replaced (car has 76k miles). I'd like something light weight like the fidanza but its pricey. Is aluminum worth it in street car daily driven. Or is the RAM billet steel pretty close in weight. Also, what is the difference between the RAM, SPEC, SLP, ect billet wheels?
im not too sure about flywheels, people say aluminum for auto x and a heavier one for drag racing because of ratational mass or whatever.. im going to be spraying on my H/C/I car and im guessing ill prob be making around 550 to the wheels so im hoping this will hold up!
So all of the steel billet flywheels are roughly same weight. only difference is when compared to the aluminum (fidanza).
This car wont see much drag time, maybe once or twice a year if that. I would like faster revs and a more autocross like setup. Is the fidanza worth it and any good gains on the street?
If this is a daily driver, then a steel flywheel will have a longer life and will be easier to drive for stop and go traffic.
What makes the steel flywheel last longer and more friendly in traffic?
Also curious if a fidanza would help make the car boost faster due to faster revs?
If it is a DD I would DEFINITLY stick with a steel flywheel whether it is billet or a stocker.
Pedal is firmer than stock but not difficult and it can be slipped some as well.
