Changing fluid in the T56
But, a few more questions: what type of pump (water, oil, gasoline, or does it make a difference?), and is it battery operated or manual?
Also, I plan on putting the front tires on ramps, then jack stands in the rear. Can I use a floor jack under the rear end housing (like the older cars)to get the rear high enough for the stands?
Thanks,
John
Yes, you can use a floor jack under the rear end, and then put jack stands under the axle. Just make sure that it is not touching the diff cover when you jack it up, otherwise it will dent the cover and you will have to buy a new one.
John
