T56 Trashed!
Old May 3, 2007 | 05:27 PM
Fraxum's Avatar
Default T56 Trashed!
I ran over a piece of metal or something in road today which smashed the tailhousing back by the driveshaft! Bummer!
I was able to drive about 5 miles to get home. Other than oil all over place it drove fine. Now the question.
Can I buy just the tail housing? Maybe I should just buy a rebuildable core and pull parts off of that?
Would any t56 93-2002 fit? I have a '97 TA. Am I kidding myslf? Will I need a new trans?
Old May 3, 2007 | 06:27 PM
styoung's Avatar
any trans from a lt1 f body will fit but not from a ls1 car.
Old May 3, 2007 | 08:17 PM
ex-SS-ve's Avatar
you can buy just a tailhousing. not hard to change out. check out sixspeedsinc ========> sponsor. talk to amber and they can get you setup. very great people to deal with!
Old May 3, 2007 | 08:47 PM
Fraxum's Avatar
Thanks, I just looked again. The main case also has a big chunk missing. I guess I will need a replacement. Looking now.
Old May 3, 2007 | 09:47 PM
qwank's Avatar
i looked up case parts the other day at the delership i work at. the tailshaft housing for the LT1 trans is discontinued from GM and the case was over $600 with my cost being 10% over dealer cost.
Old May 4, 2007 | 06:49 AM
calhoon's Avatar
A GM dealer is a poor place( the poorest) to buy transmission parts( actually any parts). You can certainly do better through a Tremec dealer. If you trans is otherwise healthy you can get any Fcar core for the case and extension as all are the same. The LT1 and LS1 models are common for these parts.
Old May 4, 2007 | 09:52 AM
Mike44138's Avatar
If sixspeedsinc.com can't help you out, you can also try Rockland Standard Gear. they'll usually want the number off the tag on the trans to be sure about the parts.
Old May 4, 2007 | 07:57 PM
Fraxum's Avatar
Thanks for all the help. I like the core idea. Maybe I can find a core good enough to use as is! I suppose I might as well throw in a new LT4 PP, disc and flywheel while I am in there.
Old May 4, 2007 | 09:10 PM
Fire-formula 93's Avatar
Go to www.t56rebuilds.com and call them up. They sell the main case for $200, sandblasted. Not sure about tailhousing, I am sure they can get one for you at a great price.
