Spec 5
was lookin at the Spec 3+ but have read alot of horror stories about the spring loaded Spec clutches and the best deal i have found on them are like $520, on the other hand i found a spec 5 for $430 and its not spring loaded and i havent read anything bad about them...
my car is NOT a DD so im not worried about drivability..
i guess my question is...have u guys heard anything back about the spec 4 or 5?
think i the spec 4 would be a lil more street friendly?i only dirve my car like 500 miles a month or so and ill be at the track quite a bit id say (if i get a clutch, lol)
i just dont want a 3 down because their spring loaded and i have heard of the srping flying out on them
Now the Spec 5 I killed within 4,000 miles at just over 700rwhp so I went with a 3+ twin disk and love it again!
This is not an area where you want to be cheap. Buying 2 clutches and having them installed in a year isn't fun.
although it doesn't get driven every day, it ONLY sees the street.
i've got about 6-7000 mile son it and when i pulled it recently to replace bad hydrolics there was minimal wear on teh clutch disk. stock is .310, mine was .305....spec says replace at .280"
it is tricky to pull out from a stop, both with the solid disc and the light flywheel. but once your'e used to it, it's not bad.
once it warms up in the morning, it makes no noise.
As a side note, and as confirmation, we sell tons of 3 and 3+ units for this application and have for years. Our overall return rate is minimal (less than 1%). This should speak for itself. Let me know if you have any further questions. Thanks!
spec is the only clutch id get though tthats for sure
seen almost every clutch out there and none have as good of a dependabilty as the spec's including there new dual setups
