spec 2 question
Old May 13, 2007 | 10:03 PM
khaos288's Avatar
Default spec 2 question
i had a shop put my clutch in, and with the spec spacer it engages barely off the floor, so we took it out, and it wouldn't engage fully, should i try and find a biggger spacer or master cylinder or what do you guys think
Old May 15, 2007 | 02:28 PM
SPEC-01's Avatar
Khaos, If the engagement point is low with the spacer installed it may be a hydraulic problem. Did you replace the slave and master (or either for that matter)? Just curious. Let me know. Thanks,
