Burnt clutch fluid
Originally Posted by blk00ss
You are using synthetic brake fluid? I always thought you was supposed to run regular dot 3???
It has a much higher boiling point than DOT 3, along with longer service life being that its a synthetic.
Originally Posted by vettenuts
I would try to keep if flushed using Ranger's method, takes only a couple of minutes and hopefully will keep clutch issues at bay.
