clutch?, drivetrain problem?
Old May 22, 2007 | 01:52 AM
Freddyrdzls1's Avatar
Default clutch?, drivetrain problem?
hey there people just wondering if i can get a little help !!!!!!!
well i have a spec 3 plus clutch with new mcleod master, and new 01 slave cylinder. well i have a little tiny problem when taking off in 1st gear, my car feels like the drive shaft shakes alot, or the clutch shakes with the flywheel, or the differencial shakes alot. im not sure what shakes, moves or what it just tugs from front to back and rattles and as soon as i let the clutch go all the way to the top, it feels fine , all the gears go in smooth and great its just taking off in 1st.
ive let other people drive it to proof that its not the driver and it happens to them too.
if i try to slip it a bit to move slowly it will do it
if i give it gas a bit and let the clutch go slowly it will do it also.
if i let the clutch go quickly and give it gas it will also do it .
some times it does not but most times it does.
what could it be?
anyone with any kind of info ??????????? let me know thanx
Old May 22, 2007 | 01:55 AM
tsench's Avatar
check your u-join
Old May 22, 2007 | 04:17 AM
soulless's Avatar
Could it be clutch chatter?
Old May 22, 2007 | 07:40 AM
teke184's Avatar
are you still breaking in the clutch/fw??
sounds like chatter to me as well.
took 1000 miles to break in my SPEC 4 and get rid of the chatter.
Old May 22, 2007 | 12:01 PM
i would say i have bout 700 miles in it and it didnt do that when it was first installed.... it feels like clutch chatter and u joints at the same time but just in 1st gear taking off..... the rest of the gears are ok and go in perfect and work fine ..... let me know ill go check my u- joints....
Old May 22, 2007 | 10:02 PM
ttt!!!
Old May 29, 2007 | 04:16 PM
anyone else????
Old May 29, 2007 | 04:25 PM
getsomebeyatch's Avatar
It sounds like you have a bad case of clutch chatter and spec is know for it. I had a spec 3 in for 6000 miles and it chattered the whole time till i went to the ls7.
Old May 30, 2007 | 10:37 AM
SPEC-01's Avatar
This sounds like chatter. If you are a little quicker coming out of the pedal is should help a bit. Chatter will generally go away with miles. It is possible that you have been so tentative with the break-in that it is still seating. I suggest progressively picking up the pace a bit in terms of your agressiveness. Let me know if you have any further questions. Thanks!
Old May 31, 2007 | 08:16 AM
hey thanx you all im going to do what u suggested and hopefully it works ok thanx alot
