Additional Question on Drill Mod?
Old Jun 5, 2007 | 07:52 PM
SSDoubleK's Avatar
Question Additional Question on Drill Mod?
I have been in the archives, found and printed out the instructions on the drill mod, and Master Cyclinder intstall, my question is, If I purchased a 01-02 Master Cyclinder do I still need to do a drill mod on the line? THanx for your input. DoubleK
Old Jun 5, 2007 | 08:11 PM
studderin's Avatar
ya...
Old Jun 5, 2007 | 09:40 PM
wrencher's Avatar
wrencher
New line with new master= a new restrictor that needs to be drilled out.
Old Jun 5, 2007 | 09:51 PM
PunkNPonys's Avatar
Yes you do.
Old Jun 5, 2007 | 09:54 PM
BriancWS6's Avatar
Yes sir.
Old Jun 5, 2007 | 10:03 PM
Proud2bSS's Avatar
The yeahs have it.....
Old Jun 7, 2007 | 09:52 PM
SSDoubleK's Avatar
Well drilled out the line, now after holding down the quick connect fitting to flush it out, the black spring part will not come all the was back flush, tryed over a hour to get it to come up whole way, looks like I'll have to switch out the lines, and do the mod again after I take the old master off the car, any suggestions?. THanx for your intput.
Old Jun 8, 2007 | 04:28 AM
TACE02's Avatar
good luck, and as for the drill mod. lol, I haven't done it and my driveline mechanic who has been working on LSx only cars for around 6 years now told me he does not recommend it. He says if you bleed it properly and your clutch components are good, then you won't have a problem. But on another note, good luck with that CenterForce, especially on a H/C car. Made that mistake once, won't happen again.
Old Jun 8, 2007 | 07:39 AM
Torkman15's Avatar
10 Second Moderator
Drill it. If you drive spiritedly at all just drill it, you wont regret it. If you dont drill it you will in a few thousand miles when you are swapping out your new smoked clutch. Good luck...
Old Jun 9, 2007 | 02:02 PM
SSDoubleK's Avatar
What's the problem with the centerforce? I'm getting ready tommorrow to put the thing in, doesn't look anymore difficult to do than other clutch brands.
Old Jun 9, 2007 | 10:23 PM
Torkman15's Avatar
10 Second Moderator
I havent seen, Ive only heard about the weights on the pressure plate make high rpm shifting tough on the hyd throw out system. Hope that helps, follow the directions in your centerforce kit and you shouldnt have any troubles.
Good luck to ya..
Old Jun 10, 2007 | 06:03 AM
SSDoubleK's Avatar
Well I bought a Centerforce Flywheel also for this clutch, hopefully I do not run into to many problems.
