After the drill mod,do I still need to bleed the Master Cyclinder?
Did a search on this, most input was that if you are upgrading to a 01-02 GM Master Cyclinder that they come prebled? If I did the drill mod, am I still okay putting it back in without bleeding it? THanx for your input. DoubleK
When I bought my new 01-02 master, I did the drill mod to it before I put it in the car. I just made sure that I didnt lose any fluid out of the master when I took the line off. when I was done I just made sure the line was filled with fluid before I put it back on to the master cylinder. I hooked up the line to the slave and pump the pedal, by about the 10th pump I had pedal pressure. I pumped the pedal about 30 times to get all the air out of the system.
Oh yea, I did flush out the debris, after the drill mod, used a bulb syringe and some tranny cooler cleaner, also what exactly is the differance between the 98-00 Master and the 01-02, they look the same, only differance is the quick connect fitting was a differant color. THanx again for your responses. DoubleK
