To All Aftermarket Clutch Owners!!!
Rule number 1,DO NOT ride a clutch.
I also have a lot of sympathy for those who are frustrated and angry after spending $750 or $1000 or more on a clutch and having it fail within a few months.
shoot....these days $700 is getting off easy for a clutch and flywheel.Mcleod....$1500 no flywheel....exedy....$1400 no flywheel....text...$1100 no flywheel.people have stated in their threads that they have stop and go traffic and floor it near idle in high gear and stupid stuff like that.some have posted riding it too.im sure not alot of these issues are a combo of problems,but repeatedly riding a clutch will cause issues.
LS1Tech Sponsor
I hope everybody on this site reads this post before buying a clutch
Today we got 3 clutch problem calls and they were 3 different brand clutches. I had to explain (again) the purpose of the clutch.
On my personal cars I'm very happy to get 4k miles out of a clutch due the abuse I give them at the track.Not afraid of 6500rpm launches and slipping them the whole 60' But most people think the clutch can take that while living 100k miles due to the fact it's a stronger clutch.
If there was one clutch that did it all they would sell a million of them. Fact is that a clutch is a wear item and a race/high hp clutch is not made to last as long as a stocker (in a stock vehicle).It is made to handle the power/abuse for shorter periods of time.
Originally Posted by Slowhawk
On my personal cars I'm very happy to get 4k miles out of a clutch due the abuse I give them at the track. Not afraid of 6500rpm launches and slipping them the whole 60'
I know I ride my stock clutch, 38k miles on it. When I ride my clutch is under 20 mph when cruising around. I do thsi cause in 1st-3rd under 1500 rpms and under 20-25 mph I have a nasty huckle bucking that the car gets into if I dont keep the clutch pressed in some. This either goes away or is not noticeable in 4th-6th at similar rpms and I dont notice it as much in 4th at those speeds though it does want to stall on me at times or I hear alot of noise from the rear.
Any ideas what is causing this? An installer told me it was my clutch going bad, but its been doing this a year. It did this after getting all my work done to it, and prior to the work it never did this. Chuckles.
Kudos to ppl who get their money and dont stand behind their work or take pride in it
LS1Tech Sponsor
Originally Posted by Gary Z
Slowhawk - How many track passes do you expect from a clutch?
My FI Vette did 24 passes with stupid abuse on a SPEC 3I.That was an awesome track clutch with Nitto's.
10 Second Moderator
Originally Posted by TARZAN
I have been mean to my CF DF and its lasted about 30K so far....
-Will
-Will
Same with my Spec stg4, I didnt know anything about torque sequence or even what torque I just put it together like I did all the old junk Ive thrown together for years, no break-in, just drove a few miles and said yup works great and then 6 grand side steps at the track. 2 years and 10,000 miles later its still NOT smokin'
Depends on which car and the power level/gear setup. I've got as many as 40 passes and as little as 4 (stock clutch/stock car -but did 12.2 in a fairly stock C5 Vette My FI Vette did 24 passes with stupid abuse on a SPEC 3I.That was an awesome track clutch with Nitto's.
#34
I had over 50 passes on my OZ700, about 5500 miles, and many of the passes were in the 10's, at 140+
When I removed it, I'd say it was just fully broke in.
Although I am not abusive on the clutch in any way.
#35
I had over 50 passes on my OZ700, about 5500 miles, and many of the passes were in the 10's, at 140+ When I removed it, I'd say it was just fully broke in.
#36
i did find that odd which was why i stated that there could be a bad batch.it wouldnt surprise me,but i am curious what flywheels all these people are using.
#37
Thanks for the info but why did you remove it?
I removed it, as I was upgrading my T56...
As for the clutch.. I admit I got caught up in a lot of the BS hype, and got it into my head, I needed ( wanted ) a "better" clutch.
So I bought an ExoSkel..
With hindsight, no I didnt need it. But then again, neither do about 80% of the people who buy it...
It wasnt an easy decision to make, as the OZ700 performed faultlessly, and drove like stock.
I knew I was going to lose this when I went to the Exo, but for some reason, I just wanted one anyway.
